ive finished doing just about everything to the Malibu that I can except for rear disc brakes.
I've swapped in an 8.5 rear end with a 373 Eaton posi with drum rears.
Are some rear disc swaps better than others? Do they all require about the same amount of work and do you always have to remove the axles in order to get the backing plates on?
If there is any way around pulling the axles that would be ideal for me because I do not like messing with my rear end setup.
