I am planning to finally put the rear disk brakes on my GP. I did the mock set up a few years ago so this winter it'll be one of my projects. In my research I have read that the end play on the axles can cause some problems with the axle forcing the pads to back off which causes a low pedal. I have also read that the axle movement can cause a pulsating pedal. Apparently GM used different C clips in the F bodies when they went to rear disk to control the side play.
I know a few of you have converted the rear brakes so have any of you experienced the problems I have read about?....Thanks for reading
