1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Rear End HELP
Discussion in 'Oldsmobile Cutlass / 442 / Hurst/Olds' started by 442Jayp, Dec 1, 2010.
Thread Status:
  1. 442Jayp
    442Jayp Master Mechanic
    Nov 11, 2010
    279
    I am about to buy a posi and 3.73 gears for my 1984 Cutlass Supreme and wanted to kno can anyone tell me the specs on a stock cutlass rear end that has no posi..want to make sure the gears and posi will fit my stock rear end
  2. STL84Calais
    STL84Calais Greasemonkey
    Feb 5, 2009
    176
    16
    Just make sure you find them to fit a GM 7.5in rear end.
  3. 442Jayp
    Nov 11, 2010
    279
    ok i will be calling back and asking questions
  4. Kris_84elky
    Kris_84elky Greasemonkey
    Nov 10, 2010
    115
    Well your going to need a posi carrier and gears that fit the 7.5 housing. I believe the 7.625 carriers and gears also fit but will require different axles because the 7.625 carriers have a different spline count for the axles. But if your going with a 7.5 carrier/gear set just make sure it uses the same spline count as your axles. Also make sure the carrier is the correct series for the gear set your getting. I believe 3.73 gears require a 3 series posi carrier. But if for some reason you can't get a 3 series carrier they sell spacer kits for the gears.
  5. 442Jayp
    Nov 11, 2010
    279
    ok now how do i check the spline count...i dont kno anything about rear ends
  6. High Roller
    High Roller Greasemonkey
    Aug 25, 2009
    180
    Cowtown USA, MN
    The '84 Cutlass came with a 7.5" rear, and 26 spline axles.
    Eaton Differential #19663-010 $520
    Moser axles #A102602 $245
    Moser #7105 Girdle cover $160 is also good idea, and weld the tubes.
  7. Kris_84elky
    Nov 10, 2010
    115
    To find the spline count you just count how many splines are on the end of the axle where it slides into the carrier. If they are the stock axles they are 26 spline but someone could of changed them. Also I forgot to mention that the pinion gear has splines on it too that match up with the drive shaft yoke. But if all the parts on your rear end are stock, then the pinion gear from the gear set should have the same spline as your yoke. Sorry if I am confusing you but really all you have to get is a 7.5 gear set and a 7.5 carrier that matches your axle spline like STL84Calais said.
  8. pontiacgp
    pontiacgp Rocket Powered Basset Hound
    Mar 31, 2006
    17,803
    990
    Kitchener, Ontario
    when you get the carrier and gears see if they have the backlash shims attached to the carrier so it'll be easier to set it up...if the bearing on the pinion is in good shape the shim for the pinion height should be good to install as is, if you do have to change the bearing do a mock up fit to check the shim on the pinion to make sure it's right...nearly all of the pinions set up in a diff will be the proper set up for another diff...and you'll want to install a new crush bushing
    I have to ask...how long does to take you to put gas in that car?
  9. 442Jayp
    Nov 11, 2010
    279
    feels like i be there for about 10 mins
Loading...
Thread Status:
Share This Page
