Rear End question
OldsCutty86
14
10
Swapping a LS1/4L60E from a 2001 Trans Am WS6 into my 86 cutlass supreme. Would I be able to use the rear end from that? Thank in advance
L92 OLDS
2,872
3,050
West Michigan
No, the Trans Am rear end will not fit in a G body. The stock 7.5” cutlass rear end you have will be OK for easy driving and one wheel peels but if you put any power to it and hook up it will likely grenade.
OldsCutty86
14
10
Th
That is good to know. Plan on having it as my daily driver. Someone told me that I had to replace it 🙄. Thank you!!
carnutjw
621
1,465
The rear end housing- no, but the differential and gears would fit with 28 spline axles for a G-body, like these:
This post might help:
Reactions: 4 users
OldsCutty86
14
10
Thanks man. I’ll upgrade to this once I start making more power
87National
663
687
eastern SD
Grab the rear disc brakes. I haven't done the upgrade myself, but I believe there is a write-up on here somewhere.
abbey castro
1,048
1,318
Harker Hts TX
the rear d
isk set up is good for swapping onto your rear. Bunches of how too's everywhere!
oldsmobile joe
2,067
3,053
mpls
