Ok this aint ny first rodeo with gear swaps.But the first time i seen this.
Did a housing swap on a 78 cutlass (was a factory v8 car).took the housing out of another 78 cutlass(was a v6 car).went to swap the 3.73 posi from the junk housing to the good one,wouldnt fit.customer said i put the gears and posi in the bad housing,but i dont remember doing it.the pinion was like too long and too short.couldnt put the washer on with the pinion nut,not enough threads to catch the crimped nut,and the carrier was sitting on the pinion,couldnt put the bearing caps back on.i ended up buying the gears and posi for 50 bux.
Came here and searched,read countless posts and pages of threads,came up with nothing other than there was a 7.5 and a 7.62 rears
I want to stuff it into my 82 GP (its a v6 car for a few more weeks).ill probably be trying to put it in this morning before i get a reply here.but whats the chances its not gonna fit my rear end??
What speedo gear do i need for 3.73s and where do i get it?ill be running a th350 when i do the motor swap
