dogshit said:No its still a good improvment. If you had track times with the 2.56s and then get some new ones with the 3.08s and no other changes you would be able to quantify it. Probably a little easier accelerating with traffic from the stop lights ie less gas pedal which should translate into a little better mileage in town. On the other side probably a little less on the interestate overall often depending on how you use your car about the same overall mileage.
