Rear Hatch Latch question
Buford T. JuSStice
341
192
Hey guys, just got done doing the rear hatch seal, put new clips in and painted the tailgate cover, painted the chrome around the glass as well as the handle semi-gloss black, and put new pistons on... but I've got a question...
Is there any way to adjust the latch in the back so there isn't as much "play" in the glass? Like, a way to bring it in a little more tightly so it doesn't jiggle when it's closed.
oldsmobile joe
2,067
3,053
mpls
If ithe latch doesn't have enough adjustment, you may have to shim it.
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
If there is a groove worn in it, you can take the glass latch off the car and build it back up with a welder, then file to shape. I had to do that.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,176
9,778
Gainesville, Fl
If there is a groove work in it, you can take the glass latch off the car and build it back up with a welder, then file to shape. I had to do that.
I agree with your solution, Mr. Quinn.
There's no adjustment for the glass hatch, but it's common that the catch becomes (worn) grooved, thereby causing the glass to become loose.
Buford T. JuSStice
341
192
I wonder if an old modeler's trick might work... super glue and baking soda. Drop a bit of super glue on a surface, and then sprinkle some baking soda on it, and you've got something that bonds pretty strongly. It's not as strong as steel, but it won't wear down parts either, and I can sand it down easily for adjustment.
  • Informative
5spdCab
1,190
1,989
Tukwila, Wa.
I had never heard that one before. I guess I haven't built enough models. Sounds like a good informative solution.
oldsmobile joe
2,067
3,053
mpls
wrap with duct tape, it will last longer.
Buford T. JuSStice
341
192
How's that old saying go again?
Oh, right. If it looks stupid, but it works, then it ain't stupid!
Tried this out, and so far it works pretty good. Glass is held nice and tight against the seal, and it doesn't wiggle nearly as much. There's still a little bit, but that has nothing to do with any gap between the latch and the striker, rather it's just play in the latch itself. I'm happy.
  • Winner
  • Creative
Reactions: 4 users
Longroof79
Oct 14, 2008
12,176
9,778
Gainesville, Fl
Hey, if it eliminates the problem and makes you happy, then mission accomplished. (y)(y)
I've actually done a similar fix on my Foxbody Capri's hatch latch. A short piece of hose and a few small tie-raps.
