Rear Main Seal Leak
Scoot-71
102
157
Rio WI
It's the Pontiac 265 which has a rope seal.
My bad, I never knew (until now) that Pontiac had a 265 cid engine, live and learn. I did research and found a 2 piece rear main seal for Pontiacs.
7,986
18,691
It's all good. Pontiac's own true malaise era engine.
8,818
7,763
jmcghee
10
I love how people are so fast to spend others money. No need to swap engines for rear seal leak Check with another shop.
CopperNick
3,352
3,014
Canada
Try either Ames Performance or Butler Performance. They both specialize in genuine Pontiac parts and speed equipment for the 301-455 platforms. Seem to recall that there is an insert kit that will convert the rope seal to a neoprene or similar version. It is true that the rope seal is a pain in the *ss and has to be installed just so or it will leak. The builder has to be Anal-OCD when doing the job which is why a lot of shops won't go near it; too much time and patience for too little payback.
Jim Rockford
308
523
Shelby,N.C.
Every 2 piece rear main seals leak. Its guaranteed thats the main reason I dont build any old SBC's , 87 and up are the best 1 piece rear main and roller cams.
Jim Rockford
308
523
Shelby,N.C.
U say your using 15w40 motor oil. I hope its not delo 400 or another diesel type oil. Very high detergent and can damage internal engine parts. Get a can of Lucas oil stop leak. Also 20w50 conventional motor oil. Try that. Should at least slow it down.
Please explain why oil would hurt the engine?
