MALIBU Rear seat fitment after mini tubs
shoedoos
406
403
All those who have done a mini tub job on their Malibu....how well did the oem upper seat seation fit after the tubs were done?
I added a 1-inch strip into the factory wheelhouse and now the back-rest sits out and leaves a large air gap between it and the lower seat section. Before I cut some of the wire framing out of the seat skeleton, thought I would ask if there were other fixes?
superbon54
755
2,439
Wisco
I’m interested in the responses and your solution, as I’m mini-tubbing mine right now. I’ve got an extra junk back seat I was thinking of modifying before doing anything to my actual seat.
19,990
Did you notch the chassis?
shoedoos
406
403
Yes, and then aligned the inner wheelhouse with the side of the notched frame.....
Firetruck1
193
300
I worked on a car in the years past with a mini tub like this (notched frame rail and a 2 inch filler strip in the tub and I think the corner of the frame was bent up out of the way and it fit right back in.
No I dont have pictures but would like to see some of your car as this is next on my list of long term goals for my Monte.
shoedoos
406
403
I made the mistake of having the seats re-upholstered before finding the problem. I think the bolt cutters will be used to cut a few of the wire ribs out.....unless anybody has a better plan?
superbon54
755
2,439
Wisco
I had heard something a while back about cutting and reweldibg the wires, but would be a pain if your upholstery is done. Where are you located? If we’re close, we can chop up my junk bottom as the guinea pig.
On a separate note, could you post some pics of your mini tub job?
shoedoos
406
403
