The rear seat floor brace that spans left and right in the rear. Is it possible to replace it without removing the body from the frame.Exactly what are you describing/asking about?
No, as it houses 2 of the body mounts. One on each side. At the minimum you’re looking at removing the body mount bolts and jacking the body up off the mounts to have enough clearance to remove it.The rear seat floor brace that spans left and right in the rear. Is it possible to replace it without removing the body from the frame.
It is rusted pretty good.No, as it houses 2 of the body mounts. One on each side. At the minimum you’re looking at removing the body mount bolts and jacking the body up off the mounts to have enough clearance to remove it.
Begs the question, why do you want to remove it?
It's the outside one.is it the one on the inside or underside? if it is the underside one, yup th ebody has to come off since as stated before; body mounts pass are there
