nawlins-tim said:
The Camino and Wagon share the same rear frame body mounts . As far as length of the frame, Wagon and Camino are both longer than the coupe and 4-door. And as the other guy said- make a quick e-mail to Conrad. He has the knowledge for sure.
Not quite correct...sedans, coupes, wagons are all the same wheelbase. Coupes and sedans share the same frame. Wagons are different at the rear mounts.
If you're going to do it right, the frame will have to come out to weld it, so while replacement sections can be done, a swap seems like a better idea to me (assuming a suitable donor can be found).
Seems like every time somebody starts asking about a frame, they never have their location in their profile. Makes it easier to know if a person might be able to help with a spare frame if we knew where you were.
