Thanks, that looks like exactly what I need. I just ordered some and more clips.Search on Ebay for trim clip studs. They are screws with a solid shank where the clips attach.
I'd say so on removing the window. I got super lucky in that my Cutlass was a factory hardtop car that some idiot had a dealer install the vinyl top at some point. When I removed it the original window trim was there along with the studs, just covered in adhesive.Thanks, that looks like exactly what I need. I just ordered some and more clips.
I'm guessing the rear window would have to come out to put these in, is that correct?
However, there was enough rust that my roof skin had to be replaced which was a blessing in disguise because I believe the outer seal on the quarter window is different....you wanna look into that.
My friend with 4 G body cars knows a glass guy. So I will have him pull the window then re-install after I get the studs and clips in.Here's a tip/idea on dealing with the filler panel. '81 Monte Carlo's & '81 up Cutlass's used the same trim & filler panel. Not being sure which mounting clips used, it may be easier to use an '82 up Monte's trim & filler as they only used top & side moldings with the lower replaced by a reshaped filler panel. From what I noticed is both plain & vinyl top cars used the same clips on the bottom.
