Rear windows on the 4 door
That 4 door guy
279
937 Dayton, Ohio
i know the factory didnt make the 4 door cutlass' with operable rear door windows. and the wing windows do work. i was wanting to know if there is a kit or a mod i can do or somethin?
Lowrider1984
Jan 18, 2010
53
6
I don't think so I have the same car and I also wanted to do the same and by the way do u know what a bare frame weigh's and on a cutlass?
That 4 door guy
279
937 Dayton, Ohio
i dont know that answer.
81 9C1
9
Even if they would go down, due to the shape of the door and the dog leg on the front of the 1/4 panel, the window can only go down about 8 inches.
That 4 door guy
279
937 Dayton, Ohio
well i would still like to do it. its just a one-off type thing. it just bugs me that it wasnt a option. i have no problem with anything else on the car, even tho its a 4 door, except the back windows. so even if it does roll down only 8 in, what do i gotta do to accomplish this task?
Blake442
6,864
1,997
Minneapolis
X2, there are no kits available to make them go down.
8 inches is generous, I doubt they'd be able to go down more than 4 or 5 inches.
There is also no inner door structure to mount a window regulator to.
Time to fix your A/C...
That 4 door guy
279
937 Dayton, Ohio
haha :rofl: my A/C is in top working order. i just wanted to do this for the haha i got it and you dont effect
supercrackerbox
385
2
Lincoln NE
Then I would suggest getting some extra front doors from a donor car and seeing what you can adapt. Bear in mind that not only do your rear doors have any sort of track mechanisms, there is probably no provisions in the glass itself to mount anything to it. You'll probably have trouble with the seals too, as the ones currently on the car are for fixed glass, not movable.
Best of luck.
That 4 door guy
279
937 Dayton, Ohio
i mean i know i will more than likely get mad at this project and spend some hours on this. but like i said, its just for the wow factor. so all in all thanx for the tips and support guys.
billyjack
468
56
Western PA
G-sedans had optional Power rear vent windows, since the rear door windows were fixed. Considering the huge amount of engineering to fit operable rear windows in a vehicle that was never set up for anything but fixed glass, I'd fit the power vents for a little bit of "wow" factor.
Bill
