I have a 78' Monte that I have picked up a low mileage 350 + .060 over short block. Running the numbers it's a 1980-84 block. It is a factory reman. type engine with cast dish top pistons and I am sure a stock type cam. I have some 062 casting vortec heads to install on it. I thought I might leave the cam in since it is no doubt mild and will be below the .450 inch lift max for the vortec heads. I have built several motors, but this will be my first with Vortec heads. So being a Vortec newbie I have a couple of questions:
1) What head gaskets should I use?
2) What torque spec for the Vortec heads on the "older" block?
3) Is the head bolt length the same for "older" heads as it is for the Vortec heads?
