Poly joints can bind even at stock HP levels. The rear suspension in these cars requires some secondary axis of rotation, which the stock rubber bushings and arms allow, roto joints also allows second axis. Poly bushings, especially used with boxed or tubed arms will bind as they don't allow secondary axis rotation. This binding can lead to snap oversteer, where a car without warning goes from understeer to oversteer condition that is nearly impossible to correct, which means you will crash if it happens.
You could box your existing ones, and add poly bushings to them. Cheap but probably not as effective as aftermarket..
In the rear I have UMI conversion uppers and UMI lowers. Both have roto joint at one end and have worked flawlessly for years.
