Hi everyone. I'm having a problem with my 87 Regal and could use some advice. My wife borrowed it today. Started right up at home and drove about 5 minutes to a store. She came out, pumped the gas once(told her she didn't have to do that after it was warmed up) and she flooded it. It cranked once, she turned the key off and then tryed cranking it again. No crank this time. She called me and tried cranking it while I was on the phone with her and nothing happened. I told her to pop the hood and wiggle the battery cables if possible and then try it. I heard it crank one more time and that was it. It was probably an hour before I was able to get to the car. I reached under and jiggled the starter wires, battery cables and checked the ignition fuse under the dash. Everything's fine. Finally had to call AAA and get it towed home. The only thing I can think is that the starter had a catastrophic failure at that exact moment. But there were never any warning signs. Never had a no crank problem in the past. No sluggish cranking, no clicking like starters usually do right before they die. All the lights work in the car so the battery is not dead, it won't even click when the key is turned. Any suggestions before I lay out in the snow and drop the starter?
Thanks
Thanks
