I'm trying to reinstall my a/c components I need to get the correct o ring seals for the drier and also the compressor
I just bought a universal A/C o ring assortment from AutoZone when I did mine. It did come with all the sizes I needed for my SS. Before you seal it up I would replace the orifice tube insert, they are cheap. I vacuumed mine and let it sit for 24 hours to make sure I didn't have any leaks. The first time I vacuumed it I had a leak at the compressor and ended up stacking o rings to get it to seal.I'm trying to reinstall my a/c components I need to get the correct o ring seals for the drier and also the compressor
I bought the same universal kit it doesn't seem like it's the right sizes a lot of play on the lineI just bought a universal A/C o ring assortment from AutoZone when I did mine. It did come with all the sizes I needed for my SS. Before you seal it up I would replace the orifice tube insert, they are cheap. I vacuumed mine and let it sit for 24 hours to make sure I didn't have any leaks. The first time I vacuumed it I had a leak at the compressor and ended up stacking o rings to get it to seal.
