Hows it going.Im about to remove my ecm.Reason being I'm running a non ecm controlled motor with Edelbrock carb and intake.and I'm using Auto meter gauges so I'm running no sensors and Im running a 200r4 once I remove the ecm the lock up function is not going to work on the transmission. so my question is can I remove all the wires from the ecm and only leave the transmission wires will it work .Or is the a way I can run a switch.Or if I remove the transmission plug completely is it a big deal for a for a Dailey driver ...thank you for your help in advance.I found treads similar to this one but no one posted the outcome thanks
