So I'm working on my 1995 F150 and I've got new (used) front and rear bumpers for it. The rear bumper is bolted to the frame with four bolts that are not gonna come out. I've tried heating them up, impact, breaker bar, penetrating oil, etc to no avail. My torch isn't meant for cutting, but a friend of mine has a plasma cutter he said I could use. I have limited experience with a plasma and I've only used one on sheet metal and thin plate. Will a plasma be able to cut through bolts? Or at least cut the heads off? The other ting to keep in mind is there is a gas tank in close proximity to the stuck bolts, about 1 1/2-3" away.
