I found a guy parting out a 87 T-type today on craigslist. Called him up on the fuel tank for my LS1 Swap, I also tried to get the 8.5 10 bolt but he had sold it earlier this morning...Anyways I pulled the tank for my swap but it didn't have the sending unit, the hole was covered though and after looking inside carefully it it only has a varnish build up on the bottom from the old gas. Now i did a bit of research and found a variety of ways to get it out ie: acetone, chains or gravel in the tank and shaking it,getting it boiled out at a radiator shop etc etc. The varnish doesn't seem to be stuck in on the metal portions i tried spraying a bit of brake clean and it broke it up the varnish on the plastic baffles though. I don't want to damage the baffles and it doesn't have any rust inside or out. It has about a half gallon of the old gas how would you guys get it out and cleaned?? ANY IDEAS??
