"REPAIR" Axle bearing.....?
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Was looking up a set of axle bearings and came across these repair axle bearings
They have a seal on both sides for when the axle gets a wear spot from the old seal, so how does oil get to the bearing?
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
I thought those were for when the original bearing spun in the housing?
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
I have no idea. I assumed it was for the wear on the axle. But still how does oil get to the bearing?
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
From the interwebs
The axle repair bearing assembly replaces both the bearing and the conventional seal requiring no additional parts. The repair bearing moves the position of the bearing and seal so that they ride on an unworn section of the axle shaft.
  • Informative
ItsnotaGN
662
1,142
Colorado
That's odd, I don't remember those having the inner seal, but that was 25 years ago when I worked at Ronk Auto Parts in Ronkonkoma. We sold a ton of them back in the day.
64nailhead
Goat Herder
Dec 1, 2014
5,704
12,213
Upstate NY
The part of the unit that goes towards the center will allow oil into the bearing, but not out. Oil will be sealed in only one direction, but will seep in the non sealing direction. I'd fill the bearing with gear oil before installing the axle.
  • Winner
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Do you need them? When I did the rear in the Pig, I was going to throw new axle bearings at it. That's when I got the "if it ain't broke, don't fix it" from my mechanic buddy. We just did the center section, filled it with synthetic, and the wheels bearings are as smooth as butter.
