Replacement steering box?
6togo
Apr 25, 2013
95
16
Whats a good replacement steering box my GN build is in need of a new box? Any of the aftermarket boxes any good?
GT_80
240
7
Massachusetts
I haven't done it yet, but many people use stock camaro ones that have a little better replacement. Fewer turns lock to lock- or go aftermarket and you can get a close ratio box but the price goes up. I can not suggest one cause I have not done any upgrades to my steering yet
mebe007
1,808
4
36
newport news, viginia
Here's the box I run
Called them and said I wanted one for a 92 trans am ws6. It's been grat. Nice and tight and close ratio
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
actually the F body ones have the same ratio, the less lock to lock is from the stops. The Z box from the F body is the one to upgrade to. As far as ratios go if you get anything less than the 12 to 1 ratio it makes the car challenging to drive on the highway, one little twitch and you have done a lane change.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,176
9,778
Gainesville, Fl
Last months Hot Rod Magazine had an article about using a '96-'98 Jeep Grand Cherokee steering box. It's essentially the same Saginaw 800 series box using the quick 12.7:1 ratio. I think it would be an alternative to finding the elusive F-body quick ratio box and gives you more options when you're junkyard hunting. Of course you'll need to use a pitman arm from an 800 equipped G-body car.
liquidh8
I have seen that too!
mebe007
1,808
4
36
they are all generic listings. my box i ordered also says to be the part # for the grand national. they are all the correct ratio and pressure but you may or may not get the interal stops etc. I chose to get the lares box through advance instead of the A1 cardone because I actually talked to lares on the phone and verified my info. it was around $160 but i feel it was worth it as what showed up was a very high quality finished piece.
L92 OLDS
2,872
3,050
West Michigan
Anubis said:
I've read several posts on other forums that you can buy a new VIN 9 G body box from Advance auto for $100 and some change. Much better option vs. an F body box... If I can find the link, I'll post it.
Here's some more specific info from Oldspower.com
Check ACDelco #36-0516561, GM p/n 88991244 (2.5 turn lock/lock) from Rockauto.com for $99.79 + $25 core charge. That's before saving the 5% discount and shipping.
It's $161.04 to your door from GMpartsdirect.com. A few years ago, this thing listed for $222.
http://www.oldspower.com/vb/showthread. ... g+gear+box
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
the F body Z steering box gives you a heavier feel on the steering wheel which I find much better at highway speeds than the G body box. The only draw back is a wider circle but that can be changed with modifying the stops. I don't mind the wider u turn cause I have a F body 36mm bar and the 255 50 17 tires will rub the bar with a G body box. If I do need to make a quicker u turn my right foot can help with that.. :mrgreen:
