Hi
I've got a leaking seal on the accumlator O ring on a THM 350. I cleaned up the area and removed the snap ring but the piston doesn't want to pop out. Is starting the engine to build pressure the wrong way to remove it? With an accumulator spring compression tool should the cap move in much?
The trans is still in the car.
Pete
Pete
