OK thinking ahead about the strong possibility of needing to upgrade my fuel system. Currently just running a stock Carter mechanical rated at 120gph. Not certain this will reliably feed my Qjet all the way down the 1/4.
Lots of options available, some better than others. The absolute best way of course is to run an in the tank electric with a regulator. Of course that's the most expensive and the most PITA way to go too.
One thing that concerns me is the return line being too small. So my question, can't you use the return line AND the vapor return line? This would save a ton of hassle bending a new line which I would probably never get bent right....
