Reverse light issue
mclellan83
4,245
9,416
Pgh, PA
It will only light when you turn the piece on the column manually, figured while the car is all tore apart if I have to run a wire or something would be easier now. What would be the easiest solution to making it work right?
Assuming an aftermarket shifter: you can reinstall the backdrive linkage from the trans to the column, use the switch in the new shifter and tie the lights in, or just use your hand to turn the column like you are now.
mclellan83
4,245
9,416
Pgh, PA
Factory shifter which is why it is weird to me that it doesn't work
mclellan83
4,245
9,416
Pgh, PA
Not totally sure where to look other than running to the column but I don't think it is there
7,987
18,693
Does the collar on the column rotate at all when you move the shifter?
hoffa65
319
416
Atlanta GA
there sould be a linkage running from the gear shift selector on the trans to the frame with a spring, then a bar runs from a lever on bottom of column to that linkage
