Richard Holdener Tests a 3800
bs009
122
232
Smashville
Been a bit of discussion about 3800's on my build thread. It just so happens that Richard Holdener is testing one of these right now so there's going to be some really good information there about them
Part 1: Getting the motor running and baseline tests:
Part 2: Tests a few common upgrades the supercharged folks do. pulley swap, headers, intake, E85
Part 3 is up now: Compound charging a 3800 with a GT45 blower and the stock supercharger
So far he has already disproved a lot of the things I've heard from people in the 3800 world in the time that I've been in it.
I'm hoping to see him pull the blower off and replace it with an L36/L26 intake to see what it can do, I'm not as interested in the M90 content but it's still been informative. Sounds like this engine is also going to be making an appearance on engine masters too! Anxious to hear what Freiburger says about it because in my mind this was the motor they should have used in the Rotsun instead of the 4.3
64nailhead
Goat Herder
Dec 1, 2014
5,704
12,215
Upstate NY
Cool stuff. A dare to be different setup.
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
The compound boost was pretty interesting. The thing that baffled me, which is why removing the blower is important, is why at 22psi it wasn't moving more air. Boost is just a measure of restriction. The fact that Holdner still won't correlate air mass, AFR (lambda) and timing bothers me to no end. He is blindly making power... and perpetuating that methodology to the masses.
Makes me not want to talk to people.
Angry Jon Bernthal GIF by NETFLIX
DRIVEN
8,074
14,533
*CENSORED*
The Rotsun came from a (former) member here named Ringers.
bs009
122
232
Smashville
From the live stream I watched it sounded like he wanted to pull more data off of these runs but didn't have time to do it. During the livestream he mentioned that he was disappointed with how much power it made at that boost level and also mentioned he expected the blower to be a restriction as he tries to make even more power down the road.
I'm suspecting that the engine masters episode is going to be about compound charging too though so I think they're going to talk about it a lot more there if that's the case and I'm sure he wouldn't want to give out any spoilers ahead of time.
I haven't seen a lot about AFR, but he definitely explored how much timing the engine wanted and different fuels too. Unless I'm missing something else that you're getting at.
motorheadmike
8,976
27,522
Cranking the boost and playing with timing isn't good enough. Holdner needs to do a more thorough job... it is borderline hacksmithing at this stage. He hasn't improved his methodologies and grown despite having incredible resources at his disposal.
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,827
Red Deer, Northern Montana territory
I dont think he can get too much more scientific unless he gets a dominator. Not enough bandwidth with an HP.
motorheadmike
8,976
27,522
The computer isn't the only thing lacking bandwidth in this scenario. I am starting to think I need to open a school. ;)
