Ridetech Rear Control Arm installation ?
Goldhawg
37
32
The Ridetech control arms I bought (for a G-body complete kit) come with a h/w kit of 1/2" bolts, when my freshly powder-coated frame appears to be 12mm bolts (definitely smaller). What did others do? Drill out (aargh!) or is there a sleeve that could go into the lower and upper control arm that mounts to the frame?
PBGBodyFan
792
1,223
Wisconsin
I ended up re-using the stock hardware, I found this to be annoying as well. My frame wasn’t powdercoated but I didn’t want to start drilling/hogging out holes either.
The front’s I did later on and their bolts work/fit fine.
565bbchevy
9,614
12,683
Michigan
If your control arms are designed for 1/2" bolts I would just drill out the frame to accommodate them, you are only drilling them another .028.
I do this every time I install jounce bars on the frame mount except I tap them for 1/2-20.
Goldhawg
37
32
Paradoxically I have no bolts associated with the fronts! (EDIT--I found the bolt kit in the box with the true turn steering pieces; no fault of Ridetech it was just in another box)
Goldhawg
37
32
Yeah, I was leaning to going this way. Still sucks that they sell a kit that doesn't work for your application. At least they should have warned; I could've had the holes drilled prior to powdercoating if I'd have known.
565bbchevy
9,614
12,683
Michigan
Maybe get a small can of POR 15 or something equivalent and dab some on the holes with a Q tip or something after drilling
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
This is the exact reason high end professional shops completely assemble a vehicle first, then take it all apart for the final finishes.
Goldhawg
37
32
Yeah, the high end shops making $$$ from somebody else. I'm going to get this Frame off restoration of my 87 GN done in 3 months of night and weekend play. Only paint will be outsourced. BTW, when I drilled thru the powder coating on the rear it came out clean--no chipping of the powder coat around the edges of the hole. I just applied some paint before bolting in to the inner part of the hole.
vandall
109
187
Seattle, WA
I know the feeling. I have been doing a build on a 68 Chevelle, did the frame powder coating and had to drill holes for the Holley motor mounts. It's a sickening feeling but I did what 565bbchevy mentioned, just dabbed some primer and paint on the exposed metal. I used full Ridetech kit as well on that and I did have to do a bit of drilling but it was prior to coating. Like you, trying to do as much work on my own as possible. Post some pics!
