its me again. im thinking about getting a roll pan for my 83 olds wagon. any tips on installing them or problems i might incounter. any advise either way whould be good. pics would be great as well. let me know.
Well I have one on my wagon. But just a fyi they dont make one for a olds wagon only malibu and if you look at a malibu the lower body line bumps out where the olds bumps in. So you will need to do a little tweaking and molding to make it look right. Thats what i did but the tend to expand and shrink with hot/cold weather which causes it to crack between filler and the actual body.sleepycutlasscruzer said:its me again. im thinking about getting a roll pan for my 83 olds wagon. any tips on installing them or problems i might incounter. any advise either way whould be good. pics would be great as well. let me know.
Longroof79 said:No, they're definitely not the same. If you look at the quarter section of a Malibu and Cutlass, you'll see that the body lines are different.
Well the tailgate is the same everything else bodu wise is different. If you want i can take a pic of my wagon with the rollpan molded in. And you can see how i did it. Just takes a little fiberglass. Now mind you mine has the outline of where the two meet. It stress cracked on a hard launch down track well worth it seeing at that time it was my first 11.50 pass. That crack doesnt even bother me.sleepycutlasscruzer said:Longroof79 said:No, they're definitely not the same. If you look at the quarter section of a Malibu and Cutlass, you'll see that the body lines are different.
i just was looking at the pics of the work you were doing and noticed that the malibu has a lower body line thats smooth on the olds. when i first got the car i was like sweet, a malibu wagon with a olds front end, Wrong! the more i talk to you guys the more i learn that there not as close as i thought!!!
=========================================================================================================sleepycutlasscruzer said:i thought that they were the same between the malibu wagon and the olds. well that inspires me to take my rough bumper cut it up,move it in and go from there. thanks for the advise!!!!
