Hey guys I got a question, is it normal for roller rockers to make a lot of noise? I have a 355ci chevy with Comp Cam Magnum roller rockers along with their high energy lifters and manley hardened push rods.
The thing is it makes a "chikachikachikachika" noise at start up and after it warms up it kinda sounds like a diesel. :? OK maybe not that bad but there is a little more noise.
I already readjusted the rockers per Comp Cams directions with a half turn at/after zero lash. I went one cylinder at a time and double checked everything so I'm pretty sure that they're all adjusted. 🙂
Also when you look at the rockers with the valve cover off they all look like they're pointing at the 12'oclock position except for number 6, they look like they're pointing at 12:02 :shock: Does that make sense?? This is when your standing at the passenger fender looking at the motor from the side.
By the way there is only about 30 miles on the motor since I put it in a couple weeks ago. Runs really strong at low rpms but I have yet to go all out full throttle, once it's broken in watch out
Thanks 😀
Cj
Thanks 😀
Cj
