Rotor cap grease
79olds510
10
Hey so recently I changed my rotors grease them up the bearings and I haven’t noticed till my brother pointed it out grease was dripping out like black grease not brake fluid because it’s find and it’s coming from the center cap of the rotor what do you guys think it might be the problem?
565bbchevy
9,590
12,612
Michigan
What kind of grease did you use and did you work the grease through the inner and outer bearings thoroughly?
79olds510
10
Let me go check I’ve been riding around fine till recently it started doing been a couple weeks after I installed them before I put the bearings i grease all around and after too I’ll look for the the bottle in a bit
