Monte1981
n00b
Aug 26, 2019
My 1981 Chevy Monte Carlo has been running very rough when idling. When I put it in drive it gets a lot worse, but at high rpm it is smooth. I’ve just replaced all of the spark plugs yesterday and it was running smoother than ever. The engine has 72,000km on it and has brand new oil, air and fuel filters. Any advice would be appreciated greatly!
pontiacgp
blank
Mar 31, 2006
29,276
20,310
Kitchener, Ontario
what did the plugs that you removed looked like? Does it idle rough cold or at operating temperature
Monte1981
n00b
Aug 26, 2019
the plugs looked really good for their age, no oil or liquid on the electrodes. The idle is rough cold and when it’s warmed up. I did find a very small crack in one of the electrodes of the new spark plug I put in, do you think that has any relevance?
79 USA 1
1,007
1,901
Cheektowaga, New York
Personally I would check for a cracked , weathered or broken vacuum lines. Replace the cracked plug and check the condition of the plug wires and the distributor cap. Just my $.02.
pontiacgp
blank
Mar 31, 2006
29,276
20,310
Kitchener, Ontario
change that plug cause that could be the cause of the rough idle
Ribbedroof
4,634
6,393
Wellston, OK
Plug wires as mentioned above. If they're the stock type/routing, the replacements available aren't nearly as good as they used to be.
