I have an '87 Monte SS with a 305 Chevy motor, carburated. When it is warm out (summer) the car will start up cold no problem, but as soon as it gets to be <50 degrees outside the car won't idle on it's own when the engine is cold without my foot on the gas. It runs choppy and the exhaust is really rich. After about 4-5 minutes the car will fast idle with no problems and will eventually warm up and run like a champ.
I've adjusted the fast idle screw a little bit eventually returning it back to it's original location and that didn't solve anything except causing the car to idle at a higher/lower RPM once warmed up. I thought it may be the heat riser or EFE valve sticking but I've heard that when they are stuck they will stick in the open postion. I have replaced the intake manifold gasket last year as well as installed a brand new converter. Both made no difference.
