Hey guys,
New to the forum and just picked up an 84 Hurst/Olds that performs a bit....strange. First let me say that the transmission was rebuilt in June of 2013, I have seen all the receipts for the work done so I believe this to be true. However, the shifting seems to have a random mind of it's own on frequent occasions. Sometimes, when I hit the gas after being stopped, it will accelerate as expected, then suddenly rev up about 1000RPMs, then jump back down to where it was. The car will also do this occasionally at highway speeds....I'll be cruising along around 70mph, approximately 2500RPMs or so, and it will suddenly rev up to about 3000RPMs, then go back down to wherever it had been. It seems to do this completely randomly maybe a couple times every 30 seconds, then not again for minutes on end.
The car is in good mechanical shape, low miles (89k) and is well sorted, but this is driving me nuts and making it not fun to drive. Not sure if it could still be something with the transmission (or TV cable perhaps) or TPS or something else. I usually work on older cars so this one is quite "modern" for me and a little out of my knowledge base. While i know it's almost impossible to diagnose a car over the internet, I'm seeing if someone else has run into this problem and what the cure might be. I also know the car was tuned up within the last 4-5 months.
Thanks,
Keith
Thanks,
Keith
