Canadian car.
VIN 2G3AR47AXD2326389
2- Canada
G3- (G) General Motors, (3) Oldsmobile Division
A- non-passive/active belts
R47- Cutlass Supreme, 2 door
A- 231 cu.in. V6
X- Check Sum Digit
D- 1983 Model Year
2- Ste. Therese Assembly
326389- Assigned Sequence number
A01- Tinted windows
A31- Power windows
A65- Bench Seat, notch back
B79- Extra Ornamentation Rear Compartment Lid
C49- Electric Rear Defogger
C60- Air Conditioning
D1J- Speedo Gear- 18 tooth
D33- Mirror, O/S, Driver Remote
E5Z- Speedometer Driven Gear Adapter Usage
E6E- Speedometer Driven Gear Sleeve
GU1- 7.5” rear gear, 2.41 ratio.
JM5- Brake Booster, Dual Diaphragm
KM9- Aluminum Intake Manifold
K19- A.I.R. Pump
K73- Alternator, 70A
LD5- 231 cu. In. V6
MX1- Sales code for 3 speed automatic transmission, TH250C. Not for parts info.
M31- 3 speed Auto TH250C
NA5- Federal Emissions Certification
NB1- Closed Loop Emissions
NK1- Gas Tank, 69 liter
NY6- Steering Gear, 605 box.
N67- SuperStock wheels, 14"
OLD- ?
QVJ- Tires, P195/75R14 white stripe, steel radial
UP8- Installation Provision, Stereo
U58- AM/FM Stereo Radio
U64- Dual Rear Speakers
U73- Fixed Mast Antenna
VK3- Front License Plate holder
VP7- ?
V1Q- ?
V1W- ?
V2E- Standard Suspension
YT9- Fisher Installed
59L- Lower body color, Beige
59U- Upper body color, Beige
6BJ- LH Front spring code
67B- Briar Brown
67I- Interior color, Briar Brown
679- Seat belt color, non passive restraints, briar brown
7BJ- RH Front Spring code
8ST- LH Rear Spring code
9ST- RH Rear Spring code
One of the things I saw was that you have the MC pitman arm, box 11. That says 605 series steering box, which is FY. If you had FA box with MC pitman arm, then you would have the 800 series box. Along with box 12 showing the CS front bar. F41 would have a CY coded bar. You have the standard suspension because you have *** for rear stabilizer bar. Usually there’s 3 numbers in block 28 for the last three of the part number of the bar.
Additionally, you have RPO V2E (standard suspension) and RPO NY6 (605 steering box) to back that up.
The blank ones are really odd. Freakin’ Canada built cars. Anyway, I believe the OLD is for the Oldsmobile line assembly at Ste. Therese. I could be wrong on that but there’s nothing I have anywhere that lists an RPO starting with “O”.
