LS1 Camaros with t-tops run identical times than non-top models...
Because GM engineers carefully designed them unlike Mr Donk, but they are still weaker than their solid roof counterparts. Going back to G bodies, how come all factory T-top cars have rear seat bracing? Factory T-tops are know to distort from hard launches so the glass not longer sits flat and seal. Some T-topped turbo Buicks have even popped the glass right off from torque twisting the body. The reason you don't see new cars with T-tops is because they can't pass current crash standards, just not strong enough.
T-tops significantly weaken the car in torsional and lateral rigidity. That means for example that when you turn a corner, the outside front wheel which takes up much of the weight will cause the frame to bend at that corner. The same thing would happen if you started driving up a ramp with only one of the front wheels, the front end of the car will twist more than the back of the car compared to one without the T-Tops.
To explain why, if you imagine a cube made of a wire frame where the bottom wires of the cube represent the rockers and lower cross members of the car, the vertical wires represent the the door posts, A-pillars, and B pillars, and the top wires represent the roof rails, windshield header and the rear roof crossmember, then it's not hard to see why a T-Top is weaker. To make a T-top, you replace the two roof rails with a single new member connecting the middle of the windshield header to the middle of the rear roof cross member. The top corners of the car are no longer supported by three structural members at 90 degrees to each other (effectively triangulating the corner), but rather by only two. In longitudinal bending, where you try to fold the front of the car on top of the rear, it's about the same strength. In lateral bending where you try to fold the car sideways, it's obviously significantly weaker because while the rockers will resist the bending at the bottom, only a single member does so at the top. Finally, in torsional bending where you try to bend the car diagonally, the lack of two roof rails makes a big difference.
So what does it matter if your car bends? The suspension can't do it's job as well keeping the wheels pointed where you want them when the frame is contorting over bumps and in corners. It also means that gaps between body panels have to be a little larger to allow the larger relative movement between them without rubbing.
Mr Donk, doesn't have anything to connect the windshield header with the rear roof crossmember. Nothing to stop longitudinal, lateral, and torsional bending. This is besides Mr Donk's car body being put under more strain and stress than a stock G because of the oversized wheels. It is a recipe for disaster. This is all pretty basic logic really.
