So I have a real good mystery revolving around an engine which is a OLDS 307.
The numbers are 3CM253487 which the terminology in the letters has me way off
Anyone out there that knows how to determine the date code on the engine from the VIN advice/information greatly appreciated. ALL olds websites about block identification has the numbers starting with a (3) oldsmobile; then a number...1,2,3, etc representing the year; and then (m) meaning made in Lansing Michigan Plant; then the serial number of the car. As you can see mine is (3); (C); (M); 253487.
BTW THis is a 81-85 engine since the casting number is a 3161-5a, the block on the side is a 5L (307) with 5A heads.
I have a couple codes near the distributor that I cannot find any information that I have no clue what they represent
right below the distributor is CFD and to the right side of the distributor is 69
