MONTE CARLO Rust Removing
chuckfenn1
117
59
i got major rust on engine part chassis that I want to get rid off. what is the best methods besides wire brushes and drill brushes. i heard Krud Kutter works to loosen and cuts the rust away. any ideas let me know..thx
565bbchevy
9,611
12,666
Michigan
Knotted wire wheel cup on an angle grinder.
Multiple styles including straight are available depending on what you are doing.
Reactions: 6 users
Supercharged111
4,923
7,701
Colorado Springs, CO
This was by far my preferred method when I did the exterior of my 1500 frame. Sanding flapwheel works well for finishing.
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
axisg
2,685
2,354
YYZ
depending on the size of the piece I prefer electrolosis if you can. It really gets everything off and leaves bare metal with minimal work. I did the air cleaner, and all the brackets from my car along with countless tools from Yard Sales
Supercharged111
4,923
7,701
abbey castro
1,046
1,313
Harker Hts TX
I'm assuming that most of us have an air compressor of some sort: HF bench top sand blast cabinet I've had over 20 years,, used for all the small parts on my off-frame restoration. The gray wood 2x4 with holes is for doing bolts/screws. It's so much fun to see the rust disappear and leave a pretty gray finish! A arms fit as well as engine brackets etc. I use sand box sand from HD. I do have some HF media for delicate parts. But... if the parts are still attached or really big get the HF sand blasting bucket and gun and use the driveway! I know that not everyone has space and equipment
D48-cKTUJufotLk5RoLhJlPGy8JzAp0fJQpA3bsKwBk-CFzfHRnRE4y-lOXbZaxqwuv9dH4y95USsclSzRaNA2kO7-DwVJK7vo1h5E7Wfz0R-P-T9I11K38mLC6lWO3J1CXmy8Pipw8FgzBJofBt5b177z3Mvbeaci8oOceNV-ZqVhra_2YmFQFc60KBqN02GDJCkTNDiymdC_iANhJDX0UDPAb_J2xDXZ0G12L_esdMWvwrV3ncTouiQtc4mCyoYssnpb2i_1JyIvkT4CA2WEkeAArbZh9cGKXH_iNiDVq_r-cPGRj3ZarnWki_DpdDLD7DGlCU9MzhLpa5uQGHjh04mhhE_zy9VS5j7hvEhZ2c-GC2BU_8PT1Ul-LGBHbpZNKH85qnFWgjNc60wyvXUV2voT72T-ULEbSV1pOdl2iuhjvIDlq_nfki7vpf43UeTpCtP2C7DIH9BGVzoendPn9-L_iEm4mEIBZ2QG3yyAaxDFKwPmNnXrZyv_LHzGPfCZ-54lgsPJTxe2-98Xb--NT7GhwSrUr87NStAE8afaK5Eu0azUyFwFQjmwQszrwLUE9liIk1IPpyfBnbne80j8A2eXX9kWpTtTIfMcufgzjJ3Qu1RFRZqAelIBylLy5wFNpyCA1SFu-PdwfhZ_lxpxBZ8grj8qWB1q2yP4QNeSBXqQUxCLfZbf6jQ7HwUg=w633-h357-no
, but if you do, make life easier by not using the muscle building steel cup wire and chemical stripping.
