Even in Arizona, we get rust. Not like in the Midwest, but rust nonetheless.
In order to pull the fuel tank so that the fuel pump could be replaced, the line connections were so rusty I had to cut one of the lines. It would have been easier to just use a short piece of fuel line, but in this case I wanted to repair, so that the normal plastic connector could still be used.
Photos attached shows the process. This is done, in the event that somebody else comes across this issue, this is a potential repair for this problem.
Rusty damage lines...
Clean up the rust, using file and sanding sponge...
Reattach cut off section...
Replace connectors, with all new plastic...
Not shown, but reinstall tank and check for leaks.
