Ok so I've tried looking up information on this I've left comments on YouTube but haven't got anything. OK so I know u can use the spindles from a 99 to 02 blazer/jimmy can the ones off the pick up work as well?
Cool ok thanks man. As far the rotors I won't need to go biggerright? just the stock ones that came on the blazer?you need the spindles from a 2wd 98-05 blazer or jimmy. pickup spindles are not the same as a blazer/jimmy. pickups are basically the same as stock gbody brakes/spindle. the blazer uses a sealed unitized wheel bearing with a slightly larger rotor and dual piston calipers.
yeah stock ones work perfectly fine for the street. just use a quality pad and your set.Cool ok thanks man. As far the rotors I won't need to go biggerright? just the stock ones that came on the blazer?
Cool man thanks so much for the reply, once I figure out how to navigate around here I'll post some pics on my El Coyeah stock ones work perfectly fine for the street. just use a quality pad and your set.
OK cool I have two places I'm going to check out here in AZ if I can't get them I'll be hitting u up for suregreat cond 98-02 2wd blazer dual piston upgrade(minus hubs,and rotors)---275.00 shipped.pm me if interested.
sounds good,we will leave the light on for youOK cool I have two places I'm going to check out here in AZ if I can't get them I'll be hitting u up for sure
I just found sum I'll post a picwaddup bro. Be sure to checkout your club Bro's vids for the correct ones to pull. He has a ton of vids on his channel in real time doing the swaps for front and rear. He also has a few threads here with pics. I'll see if I can dig em up..
LsWarren
80zUP!
