I have 4 new springs and front shocks with rear shocks is excelent shape..the drivers side rear is sagging around 3/4". Last nite I switched the rear coils, no change...then I removed the sway bar and then removed the rear shocks...the corner is still down...the only thing I can think of is the top plate for the rear coil and upper shock mount was not installed at the right position..I plan to shim the plate so the car will sit level. Has anyone seen this problem before?
