Sand Gray 83' Headliner w/photos
KiaTia
11
2
Ok. I have been looking for the correct material to replace my Sand Gray headliner for years this is as close as it gets! The material in the background is the final material not quite the same shade as the sample but once installed it will be great!
ck80
Moderator
Moderator
5,744
9,120
Ok. I have been looking for the correct material to replace my Sand Gray headliner for years this is as close as it gets! The material in the background is the final material not quite the same shade as the sample but once installed it will be great! View attachment 220756 View attachment 220757
Looks pretty close
Don't forget, once installed and in the car it will be an indirect light source showing how well the shades match, that lessens the difference a bit too usually..
My only extra tip, since I see fluorescent/led bulbs indoors.. look at it in natural sunlight too. The wavelength, also called 'heat' of the light source could be throwing it off even more than you think.
Very possible it's even more spot-on than you think it is.
