Sbc 305 build with factoey bottom end
Ratty86cutlass
13
6
Ok so one more question...this is where I'm kinda dumb ive never put an aftermarket cam in something so this is something new too me...what would be the proper cam for factory 305 heads nothing done besides heads dexked a bit do too me having to change a head gasket?? I read on motor trend somewhere they put a xstreme enery xe262h10 cam in a 305 but they said it was for later head changes...but they still seen a 40 something up gain out of it.?? Thats with a performer intake manifold too which is what I plan too run.
bracketchev1221
1,411
1,647
That cam would probably be a good choice. For a used 305, I would buy the cam kit with the new valve springs and timing chain to put it back together.
Oct 14, 2008
8,823
7,775
Melville,Saskatchewan
1320John$$$
951
2,043
Pennsylvania
I have two 305 powered mc my 85 has a HO short block 9.5 compression with ported 416casting heads edelbrock intake summit cam 600 vacuum Holley recurved HEI I had the car on a chassis dyno it made 229hp at the wheels will post picture of the printout ran 14.80s @92 mph stock th350 3.73 rear I like the little motor and it’s a small block they respond to everything
