I have a recently built sbc 406 I installed timing chain as usual crank dot up cam dot down. I ran engine on engine stand fired right up and run put engine back at tdc removed distributor and installed another distributor, tdc xero on balancer and rotor point to number 1 cylider,finally got engine to run with different distributor but has to advance distributor all the way till the vacuum advance hits the intake but it still needs more advance ANY HELP,?THANKS
