I suspect my intake manifold gaskets may be leaking vacuum. Currently I have a ZZ4 intake on my L69 305. GM recommends PN 10147994 gaskets which are coated and embossed steel shim gaskets. However, I recently read that it is generally recommended not to use steel gaskets with aluminum intakes. A few years ago I had Fel Pro 1256 printoseal intake gaskets, but they leaked vacuum due to not having sealing beads for the EGR ports. The GM gaskets do have embossed seals for the EGR ports. Moreover, a company called Magnum makes a version of printoseal style intake gaskets that do have printed seals for the EGR ports, MS18010.
In short, I am not sure if GM's recommendation is correct about using steel gaskets with their aluninum ZZ4 intakes? The intake is torqued to 30 ft/lb.
