SBC Oil Pump
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I'm switching out the BB oil pump when I replace the pan so I have been looking for a pump. I came across Mellings shark tooth pumps that have helical gears and I think I'll be getting the 10552ST. Have any of you used one of those shark tooth pumps?
vanrah
879
1,189
Near Afton, Wisconsin
Greetings; I had to take a look see right away. Very nice pump. I really liked the statement about "IMPROVED DISTRIBUTOR OPERATION - REDUCTION IN SPARK SCATTER". We as a group see & learn new things along the path. For years I fought Too much oil up top, not even knowing it for a # of years. For so many that build SB & BB Chevy's this has been a problem for years. Restrict (lifter gailies-smaller push rod holes++) this or that for a fix (the LS world only wishes) because of too much oil. On the other end of the pump the pick up is another part gets thought. I found this to be an excellent solution for the pick up, look close at the oil bottom plate. Ole' Bob.
scoti
1,972
3,385
Texas
Interesting. I haven't tried one but I'm also in the market for a fresh pump on the 408sbc I have getting pieced together. Might give one of the 'ST' series a try.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
Rock Auto doesn't have any stock but I'll get notified once the come in and I'll let you guys know
xylorex
305
395
New Orleans, LA
I ordered one for my SBC build, part #10055ST-750SS. appears to be very high quality.
unfortunately i have the body off the frame and a sh*t ton of bodywork to do before that engine starts up.
bracketchev1221
1,405
1,641
I never had any issues with the plain old Melling hv pumps. I know people claimed there was a change in the casting a few years ago but I never broke one. Ran Melling hv pumps In all my race big blocks.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I am currently running BB Melling 77 pump. The volume is around 20% volume over a Melling 55 and takes less to spin it compared to a Melling 55HV. The Melling ST standard pump is 10% higher volume compared to a Melling 55. I am going from a 7 quart pan to a stock pan and I do not like or need the high pressure that I get from the BB pump, it hits 80 on a cold startup so I'm thinking the ST pump will be puuuurfect... :popcorn:
