SBC OILPUMP INSTALLATION???'s
dickeymoore
924
Atlanta,Georgia
When installing a sbc oilpump from the bottom does the distributor have to be removed or is there a way to install oilpump with rod that goes into the distributor from bottom of the engine?Thanks
565bbchevy
9,614
12,683
Michigan
I would remove the distributor and oil pump driveshaft first and if you haven't already replace the shaft with one that has a steel collar.
64nailhead
Goat Herder
Dec 1, 2014
5,704
12,213
Upstate NY
What will cause a oilpump to stick open and shoot oil out of the oil filter
Hmmm?
What’s the oil pressure? And where is the scene of the crime (shooting)? Gasket?
565bbchevy
9,614
12,683
Michigan
Never heard of this problem, maybe an issue with the factory oil bypass valve under the filter.
ELCAM
1,122
1,270
Do you have two gaskets on the oil filter? Like the old one was stuck to the engine and you just installed the new one on top of it. Been there done that.
565bbchevy
9,614
12,683
Michigan
