SBC STOCK THROTTLE CABLE BRACKET FOR MONTE SS
81msw79
391
124
roselle park , nj
Can someone provide a few clean clear pictures of there stock monte carlo ss throttle cable bracket with a quadrajet carb? looking to see how everything mounts and what bracket i need that fits the carb with the 2004r/700r4 tv cable. thanks
MrSony
6,826
6,729
Des Moines, Iowa
MrSony
6,826
6,729
Des Moines, Iowa
You can also find these on Olds 307 cars as well, at least ones that had a 200r4 or 700r4 behind em. Although the GM one's are generally painted black, not anodized.
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
81msw79
391
124
roselle park , nj
Most of the 200r4 cars (and the TH200c) used this type of bracket that had a Qjet: http://www.jegs.com/i/TCI/890/37670...v0qvfDfrVc4okfpuXjRecn2HE1QUSbsRoCcNEQAvD_BwE
or something similar to it anyway.
Pay no mind to the reviews, they appear to be retarded. Anyone who has seen this bracket knows it only works for qjets.
with the throtle cable and tv cable that are in my car that bracket will not work at all. so the reveiws may not be far off. that bracket will be way too close to carb for my factory cables to work. i have an 83 wagon with a 350sbc and 2004r trans and the bracket bellow that SSN696 posted. did not know if it was a factory correct bracket for my needs or not. need to setup another car and the edelbrock brackets are horrible.
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
The bracket photos I posted are from a wagon with TH200C. The upper, small, hole is for the throttle cable and the lower, bigger one, is for the throttle position cable. In the first photo, at the edge of the picture, is the throttle valve connection to the QJ linkage. It has the clip in place that has a tang that reaches over the shaft and locks it in. The lower 'hatted' pin in the photo is where the plastic end of the TV cable clips on. I changed to a Vortec intake and 200-4R, so I went with the Spectre adustable one. I have not yet run the car and made all the adjustments, but it seems to fit OK.
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
i would also like to see a pic of where on the q-jet the cables will mount and in which manner.
Ed, can you oblige this fellow with a pic from that pristine survivor of yours?
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
88 Monte
Pay no attention to the red arrow
