SBO Alternator Upgrade.
amanley
36
8
8
Hey folks another day another question.. I plan on ordering some HID headlights and a Digital Dash soon. Looking to upgrade my alternator for my SBO. I was looking at SI to CS and SI to AD conversions. I have an aftermarket stereo system as well. My question is would my factory bracket work with either of these alternator housings? If not what would I use? Sorry about dust doing glass work on head panel. Ignore the trans lines and lack of shroud those will be replaced shortly.. :p
Bar50
1,180
871
Tulsa, OK
CS130 for an 88 or 89 Caprice with a 305. 105 amp, like 55-65 at idle speed. Fits where a 10 SI like came on your car.
Oct 14, 2008
8,823
7,775
Melville,Saskatchewan
I actually got a CS130 100 amp Delco reman alternator, works fine. Just tell them you have a 1988 Cutlass Supreme with a 307 and that should be the alternator they give you, same hook up as your current alternator. CS144 is bigger and requires mods.
amanley
36
8
8
I was looking at bolt patterns CS144 will work might need some finessing, but it'll work.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,176
9,778
Gainesville, Fl
You might have to re-clock it, but I think a CS alternator would be the ticket. Of course the CS144 would be more ideal to power accessories, etc. being that they putout 140 amps compared to 105., but they are a bit larger.
I'm currently using the CS130 and I love it...perfect size.
Try these people. https://alternatorparts.com/
