When doing floorboards you need to seal the new welds and seams. I know they make special seam sealers just like the factory used. The factory only used spot welds so the seams were leak points without sealer. But I also like to paint the entire floor, trunk, anywhere water could accumulate and rust. I usually use POR-15 but I found another marine product called Rustlok that is also a moisture cured urethane. It used to be called Trailer Coat and my 1989 boat trailer looks brand new because I faithfully paint it with this stuff. I think it is better than the POR-15. My concern is what to use first. The urethanes dry so hard they need to be severely sanded to re-coat. The 3M seam sealer is also urethane but it says it is paintable. So do I use the seam sealer first, then paint? Or if I paint with urethane do I still need seam sealer? Will it even stick? I know that the POR-15 does not stick well to old hard seam sealer.
