Seat belt anchor bolts
yourownself
336
38
stoughton, ma
I did a quick google search for “gm seat belt bolts” and got a ton of results.
shoedoos
406
403
you're going to struggle.....GM made the Gbody seat belt bolts an odd thread size compared to others......if you can salvage your existing ones do that
69hurstolds
8,185
17,568
No guarantees for these, the parts book is ALL OVER the place with redundant part numbers without explanation.
GM part numbers....for 1985.
Round head style. Inner seat belts to trans tunnel anchor- 15547812 (M12x1.75x40.5) Discontinued from GM.
Shoulder strap bolts- 20247369 (M12x1.75x43) superseded to p/n 19257399. Discontinued from GM.
Lower front and rear outer seat belt bolt- 9639880 Discontinued from GM.
Rear seat belt inner- 9658871. Discontinued from GM.
This is all I got. Good luck.
ChevyMC85
n00b
Nov 29, 2018
4
Ok. Thank you. This is what I found as well.
ChevyMC85
n00b
Nov 29, 2018
4
Yeah I stripped the heads pretty good removing them. Guess I will search the junk yard.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I use a well used 6" extention wih the torx bit and use my hammer to make sure the torx bit is seated, the pounding not only seats the torx bit but it also helps to free up the bolt
